Hello Guest it is November 13, 2026, 05:35:08 PM
Author Topic: Bridgeport INTERACT  (Read 25389 times)
Bridgeport INTERACT
« on: November 17, 2016, 01:24:38 AM »
i bought a new toy with a heidenhain TNC155 controller.
which is the best ethernet motion conroller for mach3/4 and this milling machine?
ist it better to change to new AC type servos?
Re: Bridgeport INTERACT
« Reply #1 on: November 22, 2016, 05:49:21 AM »
I am a big fan of the Vital systems stuff.
I would go with the DSPMC/ip for something that size that will need lots of I/O.
If the motors and drives are usable I would stay with them. A DC motor is rated for 2000 hrs between rebuilds as a general rule IIRC. If you are going to use it a lot, say 40 hours /week, then consider AC or brushless servos.
There are other options and I will let fans of them chime in.
Mike
« Reply #2 on: November 22, 2016, 06:19:32 AM »
i received the machine yesterday.
its a interact 520 from 86/87 with analog endcoders and fanuc +-10v servo amps for spindlel and axis.
i think, the best way is a cs labs ip-a or dspmc-ip with analog outputs for the axis, and a heidenain 601 exe converterf for the encoders.
so i can replace  now the heidenhain 155  "plug and play" and the servors later.
« Last Edit: November 22, 2016, 06:26:27 AM by gravie »
« Reply #3 on: November 22, 2016, 03:29:34 PM »
Sounds like a plan.
Mike
