Hello Guest it is November 01, 2026, 10:12:11 AM
Author Topic: Minor problem  (Read 9367 times)
Minor problem
« on: June 03, 2007, 07:38:10 PM »
Hi guys; I'm trying to make two pockets (Slots really) in a piece of .375 material. The "outer" slot is .250 deep and then the "inner"  slot goes through the material. To save some moves I tried setting the "Start Cut" of the inner slot to -.250 after the outer has been routed. As you can see in the attached screenshot LC acts like it Start Cut parameter is always a positive value. Setting Start Cut to 0 produces the expected result.
Have a good one.
Re: Minor problem
« Reply #1 on: June 05, 2007, 08:58:12 AM »
How did I let that one past... O will see if I can find the problem here.
Brian
www.newfangledsolutions.com
www.machsupport.com
