Hello Guest it is October 24, 2026, 05:19:54 PM
Author Topic: Thread Milling Wizard  (Read 28709 times)
« on: June 03, 2007, 01:14:58 PM »
Want to do some thread milling with a single tooth cutter.  When I use the wizard on field is Major/Minor and I am not sure what to put into this as a value the major or minor dimension?
Re: Thread Milling Wizard
« Reply #1 on: June 03, 2007, 01:21:22 PM »
I have not used it or even looked at it but could it not be meaning if you are doing an external thread you will put in the major and if doing an internal the minor?
« Reply #2 on: June 03, 2007, 01:48:49 PM »
Major and minor dia of the thread here is a link for example.
Just find out the specs for that thread.
Wes
Have a nice Day
« Reply #3 on: June 03, 2007, 01:49:59 PM »
http://www.newmantools.com/tech/threadmf.htm
sorry forgot to put it the link
Have a nice Day
« Reply #4 on: June 03, 2007, 01:59:00 PM »
Guys,
Thanks for your input... I'll give it a try and see how it goes.
Thanks again.
« Reply #5 on: June 03, 2007, 08:55:36 PM »
It might be me but that website description makes very little sense to me.  Just look at the relationship between H1 and h3.
I also tried to calculate to the outer point (above D) and that made no sense either.
If you use a thread pitch of .75mm then the long side of the 30 degree triangle is .65024 mm again that does not correlate with H1 or h3 or even (D-d3)/2 which should be very close.
I am not sure this diagram is correct at all.
« Reply #6 on: June 03, 2007, 09:30:22 PM »
thought you were just trying to figure out max and min meant here is a link so you can get excat numbers
http://www.colinusher.info/Livesteam/mewdata.html
do a search for Thread Data and it will give you several links
Wes
Have a nice Day
« Reply #7 on: June 04, 2007, 08:03:29 PM »
Well I got it to work with some help from Brian :).  I wanted to match some existing parts that I had.  They are 10 x .75 mm threads.
I used this cutter on the mill.
Thread  Cutter
Here are the test parts made from wood.
Now to try some real pieces.
Thanks for all the help!  ;D ;D
« Reply #8 on: June 05, 2007, 08:46:37 AM »
Nice! You are going to have threads on every part in the shop now ;)
Looking good!
Brian
www.newfangledsolutions.com
www.machsupport.com
« Reply #9 on: June 05, 2007, 09:00:26 AM »
Hi Dan
Can you post the real pieces aswell ?
Very curious.
Greetings:
Willem
