Hello Guest it is September 06, 2026, 04:25:31 PM
Author Topic: CV Problems / Losing steps  (Read 35000 times)
« on: June 02, 2007, 04:23:22 PM »
I am having problems with mach2 and cv and i was just wondering if anybody could maybe advise.
My gantry router has been running for a couple of years and i run mach2 v7.5 (old i know but it has always worked).
Anyway i produced a file from artcam to engrave a coin (approx 21mm dia).
If i run the file and go back and check the z position it is .3 - .4mm out of position and always upover.
So i spent all day re-tuning the motors only to find that no-matter what accel i use the machine is alway out the above amount and alway upover.
So i sent the file to a friend that has mach and a milling machine,Now this mill is rock solid and never loses steps.
But sure enough whhen he runs it he is alway out .2mm - .3mm upover.
After much debate i turned the cv off and the machine never lost a step.
I have spent many hours discussing this problem with art over the years,We always seem to get the machine to run but every now and again a new file throws a spanner in the works.
Is there anything i could do in artcam to help,Or mach2?
Regards
Mark
www.weardalecnccarving.co.uk
Re: CV Problems / Losing steps
« Reply #1 on: June 02, 2007, 07:43:25 PM »
I would Try Mach3 and see if you have the same problem... I think the enhanced pulsing could help you.
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: June 02, 2007, 07:50:47 PM »
Brian
I am already using enhanced pulseing.
The reason i stick to mach2 is because mach3 requires such a powerful computer,And i have never had problems in the past.
It just seems to be this application?
Also the friend that also tried to run the program is running mach3 lockdown.
regards
Mark
« Reply #3 on: June 02, 2007, 07:56:24 PM »
I can test the file here on the servo mill that I have here as well :)
www.machsupport.com
« Reply #4 on: June 02, 2007, 07:58:27 PM »
Where to send the file?
It's a chopped version which only runs for 10 mins.
Regards
Mark
« Reply #5 on: June 02, 2007, 08:00:16 PM »
Brett will test it and he can send it to me :)
He has a stepper mill
www.machsupport.com
« Reply #6 on: June 02, 2007, 08:06:24 PM »
Brian
I still need to put the file somewhere so you/brett can get it?
Regards
Mark
« Reply #7 on: June 02, 2007, 08:11:16 PM »
Hey Mark, you can post here on the forum. If you don't know how, watch the welcome tutor, one of the top topics in the general disscusion board.
« Reply #8 on: June 02, 2007, 08:22:59 PM »
Ok here is the chopped file.
Please run with cv turned on.
Regards
Mark
« Reply #9 on: June 03, 2007, 08:40:17 AM »
Anybody had a chance to run the file?
Regards
Mark
