Hello Guest it is November 07, 2026, 10:39:10 AM
Author Topic: Front side turning  (Read 15604 times)
Front side turning
« on: June 01, 2007, 04:33:45 AM »
Hi Art and Brian
Is there a chance you can spend a little bit attention on front side turning.
I find it diffecult to make a shape on the front side of the material.
Greetings:
Willem
Re: Front side turning
« Reply #1 on: June 01, 2007, 04:21:42 PM »
it should not matter... -X is into the stock...
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: June 02, 2007, 05:01:22 AM »
Hi Brian
Sorry i don't understand.
Maybe i did not expres myself clear i have a drawing attached with a frontview (yellow line's).
The inside is no problem , the outside is also no problem but i do not see how to make this shape on the front.
Greetings:
Willem
« Last Edit: June 02, 2007, 05:30:20 AM by W.Jansen »
« Reply #3 on: June 02, 2007, 08:31:56 AM »
I see :)
That is on the list  8)
I hope we can get to it soon
Brian
www.machsupport.com
« Reply #4 on: June 02, 2007, 08:53:42 AM »
Thanks Brian
Would be nice.
Greetings:
Willem
« Reply #5 on: October 23, 2007, 08:31:09 AM »
Hi Brian
Is it still on the list?
Thanks and greeting:
W.Jansen
« Last Edit: October 30, 2007, 09:24:09 AM by W.Jansen »
« Reply #6 on: November 11, 2007, 08:04:46 AM »
It is on the List but that is not a simple thing to do... I will have to talk to Art about the pocketing code and see if there is a way to get it to output the correct Path for the front...
thanks
Brian
www.machsupport.com
« Reply #7 on: November 11, 2007, 09:42:03 AM »
Hi Brian
I can imagine that it is a difficult question (not the question but the solution).
I appreciate your effort in this.
To me it would be a great progression in Lazycam if it would be possible.
Greetings:
Willem
