G-Code, CAD, and CAM => LazyCam (Beta) => Topic started by: W.Jansen on June 01, 2007, 05:33:45 AM
Hi Art and Brian
Is there a chance you can spend a little bit attention on front side turning.
I find it diffecult to make a shape on the front side of the material.
Greetings:
Willem
it should not matter... -X is into the stock...
Hi Brian
Sorry i don't understand.
Maybe i did not expres myself clear i have a drawing attached with a frontview (yellow line's).
The inside is no problem , the outside is also no problem but i do not see how to make this shape on the front.
Greetings:
Willem
I see :)
That is on the list 8)
I hope we can get to it soon
Brian
Thanks Brian
Would be nice.
Greetings:
Willem
Hi Brian
Is it still on the list?
Thanks and greeting:
W.Jansen
It is on the List but that is not a simple thing to do... I will have to talk to Art about the pocketing code and see if there is a way to get it to output the correct Path for the front...
thanks
Brian
Hi Brian
I can imagine that it is a difficult question (not the question but the solution).
I appreciate your effort in this.
To me it would be a great progression in Lazycam if it would be possible.
Greetings:
Willem
