Hello Guest it is October 16, 2026, 02:16:52 AM
Author Topic: I have pulled the trigger on a SuperPid 2  (Read 19554 times)
« on: October 09, 2016, 12:15:15 PM »
As the title says after I saw there was a 15% October sale for SuperPids so I went for it.
I saw a Utube of a guy called HelicopterJohn who seems to have desoldered the "screen" and mounted it on his cabinet front with attached wires, I want to try that.
I would like also for my Xbox Controller to be able to alter the speed, I wonder if that is possible?
 If anyone has any other tips and tricks I wanna get the full tinker factor from it.
regards Ford
Re: I have pulled the trigger on a SuperPid 2
« Reply #1 on: October 09, 2016, 03:29:40 PM »
The lcd screen is a plug-in so no need for soldering.
« Reply #2 on: October 09, 2016, 09:48:20 PM »
I've been using a SuperPID for a couple of years now.  I separated the display from the board.  I'm a big fan of the SuperPID.
Here is a link to my build thread on cnczone.
http://www.cnczone.com/forums/cnc-wood-router-project-log/127895-cnc-forum-post1791782.html#post1791782
I've got the cable part no in the build thread.
« Reply #3 on: October 10, 2016, 08:54:30 AM »
Thanks RickinBC I searched my supplier for the flat cable HCMS-16-T-24.00-02 but got nowhere (I live in Norway)
Is the flat cable a 16 core with a male pin on one end and a female on the other,
not unlike the ones that go to old fashioned hard discs on computers?
thanks for the replys guys :)
« Reply #4 on: October 12, 2016, 08:39:12 PM »
« Reply #5 on: October 12, 2016, 11:09:32 PM »
It appears you need a 16 pin IDC cable, male / female from the part numbers listed of your chosen lenght
It's the male / female part that can limit supply as most are female / female... also known as a translator cable... as one end has pins and the other a socket
There are some on fleebay
https://www.google.co.uk/url?sa=t&source=web&rct=j&url=http://suddendocs.samtec.com/catalog_english/hcsd.pdf&ved=0ahUKEwjepNue8tbPAhWsBcAKHZt_CkcQFggbMAA&usg=AFQjCNFb3LqT7cTFyfAYgunw_0lMCRa6Hg&sig2=yqFgI-IEFTxImKQuew5HeQ
Cnczone quote:
Devastator 01:59 PM 12-19-2012
After much research, trial and tribulation, I finally have the correct cable.
Here's the Samtech part number: HCMS-16-T-24.00-02
That's for the 24" cable. If you wanted a 12" cable, the part number would be: HCMS-16-T-12.00-02
The cable fits nice and snug. No tape, rubber bands, zip ties needed.
The recommendation to keep the cable short is a good one. The scroll text at start up is not as clean with the cable on, but all other function is perfect.
Attached: solslyva 001.jpg‎ (71.5 KB) solslyva 002.jpg‎ (45.7 KB)
http://www.cnczone.com/forums/diy-cnc-router-table-machines/169037-anyone-mount-spid-electronics-box-3.html
« Last Edit: October 12, 2016, 11:13:44 PM by robertspark »
Rob
« Reply #7 on: October 13, 2016, 04:36:25 AM »
They will probably work... although not sure about the pin spacing.... suggest cable tieing them together to provide a bit of rigidity as a bundle... if you have a hot glue gun. You could apply a bit of glue to the back of the connectors once installed and it would then make them into a more singular connector. Less chance of working their way out with vibration over time or anything like that.
Rob
« Reply #8 on: October 14, 2016, 05:15:38 AM »
I found this bezel for the 16x2 lcd on thingyverse
http://www.thingiverse.com/thing:252464
« Reply #9 on: October 15, 2016, 11:32:03 AM »
I designed this bezel for the 16x2 lcd screens
« Last Edit: October 15, 2016, 11:34:11 AM by Ford Prefect »
