Hello Guest it is October 20, 2026, 07:41:56 PM
Author Topic: Mach3 - Jog Works but Step and MDI do not !!  (Read 8189 times)
« on: October 06, 2016, 09:30:45 AM »
Mach3 Fresh install and setup on a Win7 - 32bit machine.
Mach3 ver. 3.043.066 DEMO
I am able to jog all 3 axes without issue.
But get no movement when using STEP or MDI.
Oddly, when I switch between STEP and JOG, MACH3 requires a RESET.
I have a couple machines that use Mach3 and have never had this issue.
Digging around on the NET I found another person who posted the same issue, but no response was given.
Thank you in advance for your response.
Re: Mach3 - Jog Works but Step and MDI do not !!
« Reply #1 on: October 06, 2016, 04:07:56 PM »
If you attach your xml then maybe the issue can be found.
