Hello Guest it is October 21, 2026, 05:28:55 PM
Author Topic: Motor tuning  (Read 18002 times)
Motor tuning
« on: September 18, 2016, 03:21:58 PM »
My home got hit by lightning so I had to buy a new computer. I got everything off my hard drive. The only screen  that will not come up is motor tuning. What can I do?
Re: Motor tuning
« Reply #1 on: September 18, 2016, 03:31:21 PM »
What version of Mach and what Win program?
Re: Motor tuning
« Reply #2 on: September 18, 2016, 03:32:33 PM »
I am running mach3 on windows 10
Re: Motor tuning
« Reply #3 on: September 18, 2016, 03:36:11 PM »
Here are the requirements for a pc, doesn't mention Win 10.........
Requirements if using the parallel port for machine control: •Desktop PC (Laptops are not supported) with at least one parallel port
•32-bit version of Windows 2000, Windows XP, Windows Vista, or Windows 7 (64-bit versions will not work)
•1Ghz CPU
•512MB RAM
•Non-integrated Video Card with 32MB RAM(Large G-code files, especially 3D files will require a video card with 512MB RAM or higher)
Requirements if using an external motion device for machine control: •An appropriate external motion controller (options can be found on the Plugins page)
•Desktop or Laptop with Windows 2000, Windows XP, Windows Vista, Windows 7, or Windows 8
•1Ghz CPU
•512MB RAM
•Video Card with 32MB RAM(Large G-code files, especially 3D files will require a video card with 512MB RAM or higher)
Re: Motor tuning
« Reply #4 on: September 18, 2016, 03:42:21 PM »
BTW,
Both of my current  "dated" PC's, one a laptop other a tower and they both  use a dual boot systems.
Xp is used for Mach 3 and WIn 7 64 -bit version is used for normal things, but , I use a dedicated Xp
pc for my cnc machines.
FWIW,
Need to say, to use  the dual boot your will be memory limited / reduced.
« Last Edit: September 18, 2016, 03:44:53 PM by RICH »
Re: Motor tuning
« Reply #5 on: September 18, 2016, 03:45:52 PM »
I got lots of ram and storage twice as much as a normal computer
Re: Motor tuning
« Reply #6 on: September 18, 2016, 03:51:01 PM »
Do a search ( windows 10) and you will find info relative  to using windows 10 and Mach.
Can't be of more help, just somewhat deliberately dated on the Win systems, :)
« Last Edit: September 18, 2016, 03:52:51 PM by RICH »
Offline rdean
  •  94 94
Re: Motor tuning
« Reply #7 on: September 19, 2016, 03:31:14 PM »
Same thing happened to me once with a XP machine.  Everything worked but no motor tuning page.  I saved my xml file to a different location and reinstalled Mach3.  Brought the file back to Mach3 folder and everything is fine again.
Ray
Re: Motor tuning
« Reply #8 on: September 21, 2016, 05:23:33 PM »
Did you install Mach or just simply copy the folder over from the old drive?
Re: Motor tuning
« Reply #9 on: September 21, 2016, 05:29:18 PM »
We just copied it from the old hard drive. We don't know if it was cerupted or not.
