Hello Guest it is September 06, 2026, 03:25:41 AM
Author Topic: Help needed v carve to mach3  (Read 17738 times)
« on: September 16, 2016, 02:42:03 PM »
Hi chaps.I have a problem.my mill cuts find.on checking the movement of the tool using test g code and also the mach software,all is ok. The mill is set for mm. I made a simple square design using v carve.but when using the g code.the mill cuts far to large.both the mill and the g code is set to mm.
Can anyone help me out here.
Re: Help needed v carve to mach3
« Reply #1 on: September 16, 2016, 03:11:39 PM »
how much too big? like 10 times?
I suppose you have tuned your machine?
« Reply #2 on: September 16, 2016, 03:16:02 PM »
Hi.yes the machine is tuned. Parts come out around 150% larger
« Reply #3 on: September 16, 2016, 04:52:55 PM »
is it all the same for all axis?
I am asking because I get confused sometimes, it goes like this
open your tape measure and pull it out for 1/2 a meter and it says 50 but its not 50mm its 500mm,
my guts say check your dimensions in the drawing programme
Offline olf20
  •  325 325
« Reply #4 on: September 16, 2016, 06:22:46 PM »
Another thought is; what post processor are you using in Vcarve?
olf20 / Bob
Mach3, Atlas Knee Mill, 4th Axis, VcarvePro, ESS, Super PID.
Been Heating with corn since 1998
« Reply #5 on: September 17, 2016, 02:56:49 PM »
hi, I posted the code using Mach2/3 ATC Arcs (mm)(*txt)       I have know idea what is going wrong here.
« Reply #6 on: September 17, 2016, 05:38:55 PM »
The answer is right in the g-code. Is the code it producing the same size as the part you drew? Have you put a tool diameter in v-carve and are you cutting inside or outside of a profile?
« Reply #7 on: September 18, 2016, 03:05:08 AM »
h. I ran the g code in an editor before posting to the machine. the cuts are inside and yes I did input tool diameter into vcarve. could it be the way that mach is reading the g code ????
« Reply #8 on: September 18, 2016, 04:40:58 AM »
your not giving enough info for us to make any judgement!!!!
Saying it doesnt work is not enough!
Please tell us in detail what calibrating you have done. :)
have you looked at utube for help?
try looking at this video please https://www.youtube.com/watch?v=LRagjLewSJg
sorry if I come across strongly but unless we have decent info we are just guessing
« Reply #9 on: September 18, 2016, 04:50:25 AM »
Hi. I have used the mach 3 software to scale the stepper motors, and they move the correct distance on each axis. I have reduced the motor accelerate, I have checked that the mach 3 is in the mm setting.i have made sure that the correct ccutting tool dimensions are bring used.
I have used the road runner demo and it cuts correctly. But when I try to cut with the vcarve g code, the machine trys to cut to large a work and I need to end the process as the machine runs off the bed.
I have ulso used Cam editor to read the g code produced by vcarve and the diameters come out correctly.
And you are not coming on to strong, I am glad of the help.
