Hello Guest it is November 20, 2026, 02:42:10 AM
Author Topic: Help needed v carve to mach3  (Read 18601 times)
Re: Help needed v carve to mach3
« Reply #10 on: September 18, 2016, 07:38:47 AM »
fine :)
Did you follow the video, and used a measuring stick on the tip of a vbit? this is important!
dont forget "50 on your tape measure is 500mm"
if you did follow this video
then its the problem is in v-carve, make sure that one of the first 20 lines in the finished gcode from V-carve has a G21 command (for mm) (G20 for inches)
the G21 line in my gcode looks like this
N160G00G21G17G90G40G49G80
without the colour red
if its there in the finished gcode then check again the distances again in v-carve
« Reply #11 on: September 18, 2016, 09:02:40 AM »
Thanks.Will take a long look and get back
