Hello Guest it is November 22, 2026, 09:17:19 AM
Author Topic: ESS & C25 Wiring help for home switches  (Read 7546 times)
« on: September 09, 2016, 10:02:44 PM »
I'm hoping someone can walk me through the wiring for my mechanical home switches for my 3 axis router.
My router came with the three switches wired Normally Closed and connected to inputs 10, 11, 12 on the C25 and a common Ground on the C25.  I could not get a reliable connection in Mach4 for all three switches with this wiring scheme.
Reading the manual for the C25 seemed to suggest that each switch should be wired from a 5V terminal on the C25 to its input terminal (10, 11, 12.)  I tried this with a common 5V connection to all three switches but I'm still not seeing the correct behaviour in Mach4.
Any suggestions would be greatly appreciated.
Re: ESS & C25 Wiring help for home switches
« Reply #1 on: September 10, 2016, 10:26:53 AM »
Ah now I'm finding that the problem seems to be one of the switches itself, or its connecting wires.
« Reply #2 on: September 11, 2016, 01:31:30 PM »
Yup it was a faulty switch.
