Hello Guest it is November 22, 2026, 09:04:55 AM
Author Topic: Dry Run Mode  (Read 11061 times)
Offline TDAY
  •  165 165
    • Home CNC Stuff
Dry Run Mode
« on: September 09, 2016, 12:02:59 PM »
Hello all,
 How can Mach4 be put into a "Dry Run" mode? So one could run Gcode and preview it on toolpath, without any physical machine movement. Is there any Lua code that could be put into a button to change motion device to the Simulation Device?
Troy
"I try to put forth the effort,before asking a dum question"
http://homecncstuff.elementfx.com
Offline DazTheGas
  •  778 778
  • DazTheGas
Re: Dry Run Mode
« Reply #1 on: September 09, 2016, 02:09:03 PM »
I have a relay that supplies the mains power to the psu that supplies my drivers/steppers, so whether I am testing the gui or running the machine I just press a toggle button onscreen.
DazTheGas
Offline TDAY
  •  165 165
    • Home CNC Stuff
Re: Dry Run Mode
« Reply #2 on: September 09, 2016, 04:36:55 PM »
My setup is AC servos, so i cant do that. Mach3 had the option of disabling all outputs so you could simulate a run. Seems like there would be something like this in Mach4?
Re: Dry Run Mode
« Reply #3 on: September 10, 2016, 04:57:08 PM »
Can you not just step through the code with the keyboard ?
Offline TDAY
  •  165 165
    • Home CNC Stuff
Re: Dry Run Mode
« Reply #4 on: September 10, 2016, 06:03:03 PM »
It would be much nicer and more industry standard if you can do a dry run before actual machine motion. There is nothing like Mach3s OEM code 178(OfflineToggle), for Mach4?
Troy
