Hello Guest it is November 01, 2026, 11:43:07 AM
Author Topic: Cann't find Mach3  (Read 25710 times)
Re: Cann't find Mach3
« Reply #10 on: May 30, 2007, 07:11:01 AM »
Do you have the latest rev? and where are you saving the file to? Try to save it to your desktop then reopen the file.
www.newfangledsolutions.com
www.machsupport.com
« Reply #11 on: May 30, 2007, 08:06:52 AM »
I have LCam 2.02 and Mach3, 065.
Here's what I did this time:
I opened an Autocad generated .dxf in Laxycam, it opens fine, I make my changes, clean, optomize etc and I saved the file to my desktop. before closing I Post code to Mach3 and it goes to Mach3, everything woirks fine.
The problem is when I close that Lcam file and open it up again without quiting Lazycam, or even if I quit and start over, it appears to open fine in Lazycam, all the info in there just like I saved it, but when I try and post it to Mach3, it says "File could not be opened.
« Reply #12 on: June 03, 2007, 04:39:07 PM »
Should be fixed in the new rev... it is on the web now :)
Brian
www.machsupport.com
