Hello Guest it is November 13, 2026, 09:46:53 AM
Author Topic: Pocketing Problems  (Read 9163 times)
Pocketing Problems
« on: August 21, 2016, 02:32:27 PM »
Well back again with more of the same problems.
After 2 weeks of replacing bearings , squaring up the machine and adjustments after my machine mysteriously went off the job dimensions and into my clamping system I finally have been running test pieces.
Thought I had everything pretty good.  I decided to try a Vcarve Inlay since I finally got them working after months before this collapse.
The machine just kept going around the same first pocketing cut , a complete loop from inside the vector but never moving outwards to take out/pocket more material.  It runs an initial loop and just keeps repeating over and over in the same pattern.
All my settings are the same, I did not mess with anything.  I looked at stepover and it is the same as always in which I have had success before.
I am using Aspire 8.5 and Mach3
Anyone ever have this problem before?
TIA
  •  9,377 9,377
Re: Pocketing Problems
« Reply #1 on: August 22, 2016, 12:32:57 AM »
If you attach you Gcode file it can be tested.
