Mach Discussion => General Mach Discussion => Topic started by: jackson74 on August 21, 2016, 03:32:27 PM
Well back again with more of the same problems.
After 2 weeks of replacing bearings , squaring up the machine and adjustments after my machine mysteriously went off the job dimensions and into my clamping system I finally have been running test pieces.
Thought I had everything pretty good. I decided to try a Vcarve Inlay since I finally got them working after months before this collapse.
The machine just kept going around the same first pocketing cut , a complete loop from inside the vector but never moving outwards to take out/pocket more material. It runs an initial loop and just keeps repeating over and over in the same pattern.
All my settings are the same, I did not mess with anything. I looked at stepover and it is the same as always in which I have had success before.
I am using Aspire 8.5 and Mach3
Anyone ever have this problem before?
TIA
If you attach you Gcode file it can be tested.
