Hello Guest it is November 03, 2026, 09:17:16 PM
Author Topic: MIKRON WF3 RETROFIT  (Read 150189 times)
Re: MIKRON WF3 RETROFIT
« Reply #40 on: February 05, 2017, 11:05:17 AM »
the gear changing works, but still not perfect
https://youtu.be/y3hXnMe5g_8
« Reply #41 on: February 05, 2017, 11:07:10 AM »
« Reply #42 on: December 29, 2017, 08:28:00 AM »
Hey, how is your progress? I have some small adjustments to make on mine and then hopefully I will run my machine on the end of January 2018
Still having some position correction we are talking 0.005mm the motor is constantly searching for the position.
« Reply #43 on: February 18, 2018, 06:24:20 AM »
hallo slovenec,
it runs, but it needs fine tuning.
there are on all axis belt driven ball screws without gears.
« Reply #44 on: February 18, 2018, 06:29:12 AM »
before
« Reply #45 on: March 05, 2018, 11:42:37 AM »
Nice job! It looks like new. Can you help me with another mather . Which pull stud are you using the thing on the SK40 tool holder?
I can’t find one that will clamp into my microne.
Bestr regards
A picture for reference
http://www.lyndexnikken.com/images/files/CAT40-Mori-Pullstud.jpg
« Reply #47 on: March 06, 2018, 03:26:10 AM »
Ooo man thanks !!! You saved me ! I was losing my mind wich pull stud is the right one !
Thanks alot!
Best regards
I will upload some pictures of my machine.
« Reply #48 on: March 16, 2018, 03:13:52 PM »
Greetings,
can you help me some more? I have trouble with oil in the upper side in the motor spindle.
I filed some oil in the second hole, and the level raised in the first (oil level checker) in the second it looks like oil is in.
I don't have a clue how much oil t put in and are the two holes in the same oil tank?
I searched the whole internet for manuals Mikron wf3  and all I found are manuals for wf2 and some *********....
Do you know something about this?
Here are some pictures
https://ibb.co/dMgr4c
https://ibb.co/kZKNAH
https://ibb.co/j9WPPc
« Reply #49 on: March 16, 2018, 03:16:09 PM »
