Hello Guest it is November 13, 2026, 05:14:32 PM
Author Topic: MIKRON WF3 RETROFIT  (Read 151545 times)
MIKRON WF3 RETROFIT
« on: August 21, 2016, 04:32:35 AM »
My new Project
Mach 3 or 4, Mikron WF3, CS Labs Controller,
Backpack case for the original control panel
Touch screen
« Last Edit: August 21, 2016, 04:36:36 AM by gravie »
Re: MIKRON WF3 RETROFIT
« Reply #1 on: August 21, 2016, 04:33:46 AM »
The work after 2 days
« Reply #2 on: August 21, 2016, 05:04:41 AM »
The big problem is the manual gear box.
I want to use a frequency converter and change only one gear with a belimo actuator......i hope it works.
any other idea?
for the linear scale i use a heidenhain EXE 602 e converter (sinus wave to ttl) box.
« Reply #3 on: August 21, 2016, 06:22:03 AM »
1. Step
TNC 131  out and CS LABS with Heidenhain EXE602E and   frequency inverter in with the original servos.
2. Step
Modify Gearbox and ballscrew spindles
3. Step
DIY Tool Changer
4. Step
4.Axis
« Last Edit: August 21, 2016, 06:27:29 AM by gravie »
« Reply #4 on: August 22, 2016, 05:01:48 PM »
Looks like a nice machine, looking forward to seeing the progress :)
« Reply #5 on: August 24, 2016, 01:09:38 AM »
i have a question about the BBC servo amp.
mikron use a switch ( phase cange for motor and endcoder)  after the servo amp for + and -  feed.
but can i use the BBC servo axodyn 05LE  amp with +-10volt for + and - feed?
i connect the cs labs io to pin 3 (Vref+) and pin (Vref-).
« Last Edit: August 24, 2016, 01:29:10 AM by gravie »
« Reply #6 on: August 24, 2016, 04:36:16 AM »
the motor is a
http://callantechnology.com/callan_technology_products/TT-295X/TT-295X.html
kollmorgen/inland/callan TT2952B.
can i buy an alternativ controller for the servo motor?
i think, the BBC AMP only controll the speed and not the direction.
« Reply #7 on: August 24, 2016, 03:35:27 PM »
after using google i found the follow motion controller with +-10v input:
Advanced Motion Controls Brush Type PWM Servo Amplifier 12A8K
or
Callan AS-80-8/15 DC SERVO AMPLIFIER
« Reply #8 on: August 24, 2016, 04:22:24 PM »
I don't think the Amp will only control speed unless it was meant for something like a spindle.
I will have a search and see if I can find a manual for it in English as afraid I do not know German.
« Reply #9 on: August 24, 2016, 04:30:12 PM »
Ok, it is indeed just a speed controller, was this used on the machine before?
Was it just used as a power feed of some sort?
