Hello Guest it is September 25, 2026, 06:02:47 PM
Author Topic: mcX360 Plugin for Lua  (Read 231300 times)
Offline DazTheGas
  •  778 778
  • DazTheGas
« on: August 20, 2016, 10:17:57 AM »
Heres a different kind of plugin for you using an X360 controller that populates registry values so you can write your own scripts for it, if you have the registry plugin loaded you can see the values.
I will try and get some video`s on usage as soon as possible but is straight forward, create a lua panel from the screen editor and make sure you select that its hidden and in the code add as an example
Code: [Select]
local X360_PNL = mcLuaPanelParent;
    function GetXin(xinput)
    local hreg = mc.mcRegGetHandle(inst, string.format("mcX360_LUA/%s", xinput))
    return mc.mcRegGetValueString(hreg)
    end
X360_timer = wx.wxTimer(X360_PNL)
    X360_PNL:Connect(wx.wxEVT_TIMER,   function (event)
    if GetXin("Btn_A") == "1" then
     -- do something after button A is pressed
    end
    if GetXin("Btn_B") == "1" then
     -- do something after button B is pressed
    end
    end)
    X360_timer:Start(100)
You should get the gist ;-)
DazTheGas
Offline Bx3mE
  •  68 68
Re: mcX360 Plugin for Lua
« Reply #1 on: November 26, 2016, 05:58:57 PM »
Well... First shaky steps in LUA... but... IT WORKS!!
I have acceleration control on ZAxis for jogging... :D >:D ??? >:D ;D ;D ;D ;D ;D
Do you know a better way to do this:
mc.mcJogSetRate(inst, mc.Z_AXIS, tonumber(string.format("%s", rthy)));
because
mc.mcJogSetRate(inst, mc.Z_AXIS, tonumber(rthy));
does not work for me...
...or should i use another method for :" mc.mcRegGetValueString(hreg)".
Anyway here is my Hidden LUA Panel CODE... And i have only run it on the simulator.....
Needs some error handling etc.... adding X,Y and A axis. That will be a start!!
Code: [Select]
    end
        mc.mcCntlSetLastError(inst, "X360_BTN_A Pressed")
    end
    if GetXin("Btn_X") == "1" then
        mc.mcCntlSetLastError(inst, "X360_BTN_X Pressed")
    end
    local rthy;
    rthy = GetXin("RTH_Y_Val");
    if rthy > "0" then
        mc.mcCntlSetLastError(inst, string.format("X360_RTH_X_UP/%s", rthy));
        mc.mcJogVelocityStart(inst, mc.Z_AXIS, mc.MC_JOG_POS);
    end
    if rthy < "0" then
        mc.mcCntlSetLastError(inst, string.format("X360_RTH_X_DOWN/%s", rthy));
        mc.mcJogVelocityStart(inst, mc.Z_AXIS, mc.MC_JOG_NEG);
    end
    if rthy == "0" then
        mc.mcCntlSetLastError(inst, "X360_RTH_X_CENTER");
        mc.mcJogVelocityStop(inst, mc.Z_AXIS);
    end
    end)
« Last Edit: November 26, 2016, 06:11:57 PM by Bx3mE »
Offline Bx3mE
  •  68 68
« Reply #2 on: November 27, 2016, 02:17:14 PM »
1:st Version of my script.
Thanks Joakim (Auth of Playstation Controller plugin for mach 3 for security idea :D )
Changes JogRate on different stick position, and requires both RS and LS to be pressed to activate jogging.
I will make it more efficient (codewise) and reduce number of used lines.
I will also be working on E-Stop and Machine enable and some other stuff maybe :P
Feel Free to try it out!
If you have trouble running it check Axis references. In my old profile i have to reference "Z-Axis" and in my new i have to reference "mc.AXIS0".
Good Luck!
Code: [Select]
    function GetX360(xinput)
    end
    if GetX360("Btn_A") == "1" then
--mc.mcJogSetInc(inst, X_AXIS, .010)
--Run MDI
    --wx.wxMessageBox("Do MDI")
    end
    if GetX360("Btn_X") == "1" then
--Run MDI
    end
---- CONFIG
    local DeadZone = 25; --Based on controller output value (-99 => 99)
    local MaxJogSpeed = 25; --Percentage of axix max speed
local RTHY_MapToMashineAxis = mc.AXIS2; -- Z-AXIS
local RTHX_MapToMashineAxis = mc.AXIS3; -- A-AXIS
local LTHY_MapToMashineAxis = mc.AXIS0; -- X-AXIS
local LTHX_MapToMashineAxis = mc.AXIS1; -- Y-AXIS
---- RIGHTHAND THUMB Y-AXIS
    local rthy = GetX360("RTH_Y_Val");
if (tonumber(rthy) >= (DeadZone*-1)) and (tonumber(rthy) <= DeadZone) then
        mc.mcCntlSetLastError(inst, "X360_RTH_Y_CENTER_Begin");
        mc.mcJogSetRate(inst, RTHY_MapToMashineAxis, 0);
        mc.mcJogVelocityStop(inst, RTHY_MapToMashineAxis);
        mc.mcCntlSetLastError(inst, "X360_RTH_Y_CENTER_end");
    else
        -- SECURITY MEASURE -- Require Both triggerbuttons to be pressed...
        if (GetX360("Btn_RS") == "1" ) and (GetX360("Btn_LS") == "1" )then
            if rthy > "0" then
                mc.mcCntlSetLastError(inst, string.format("B_X360_RTH_Y_UP (%s)", (((tonumber(rthy)-DeadZone)/(100-DeadZone))*MaxJogSpeed)));
                mc.mcJogSetRate(inst, RTHY_MapToMashineAxis, (((tonumber(rthy)-DeadZone)/(100-DeadZone))*MaxJogSpeed));
                mc.mcJogVelocityStart(inst, RTHY_MapToMashineAxis, mc.MC_JOG_POS);
                mc.mcCntlSetLastError(inst, string.format("E_X360_RTH_Y_UP (%s)", (((tonumber(rthy)-DeadZone)/(100-DeadZone))*MaxJogSpeed)));
            elseif rthy < "0" then
                mc.mcCntlSetLastError(inst, string.format("B_X360_RTH_Y_DOWN (%s)", (((tonumber(rthy)+DeadZone)/(100-DeadZone))*MaxJogSpeed)));
                mc.mcJogSetRate(inst, RTHY_MapToMashineAxis, ((((tonumber(rthy)+DeadZone)/(100-DeadZone))*MaxJogSpeed)*-1));
                mc.mcJogVelocityStart(inst, RTHY_MapToMashineAxis, mc.MC_JOG_NEG);
                mc.mcCntlSetLastError(inst, string.format("E_X360_RTH_Y_DOWN (%s)", (((tonumber(rthy)+DeadZone)/(100-DeadZone))*MaxJogSpeed)));
            end
        end --SECURITY MEASURE
    end -- RIGHTHAND THUMB Y-AXIS
---- RIGHTHAND THUMB X-AXIS
    local rthx = GetX360("RTH_X_Val");
if (tonumber(rthx) >= (DeadZone*-1)) and (tonumber(rthx) <= DeadZone) then
        --mc.mcCntlSetLastError(inst, "X360_RTH_X_CENTER_Begin");
        mc.mcJogSetRate(inst, RTHX_MapToMashineAxis, 0);
        mc.mcJogVelocityStop(inst, RTHX_MapToMashineAxis);
        --mc.mcCntlSetLastError(inst, "X360_RTH_X_CENTER_end");
    else
            if rthx > "0" then
                --mc.mcCntlSetLastError(inst, string.format("B_X360_RTH_X_UP (%s)", (((tonumber(rthx)-DeadZone)/(100-DeadZone))*MaxJogSpeed)));
                mc.mcJogSetRate(inst, RTHX_MapToMashineAxis, (((tonumber(rthx)-DeadZone)/(100-DeadZone))*MaxJogSpeed));
                mc.mcJogVelocityStart(inst, RTHX_MapToMashineAxis, mc.MC_JOG_POS);
                --mc.mcCntlSetLastError(inst, string.format("E_X360_RTH_X_UP (%s)", (((tonumber(rthx)-DeadZone)/(100-DeadZone))*MaxJogSpeed)));
            elseif rthx < "0" then
                --mc.mcCntlSetLastError(inst, string.format("B_X360_RTH_X_DOWN (%s)", (((tonumber(rthx)+DeadZone)/(100-DeadZone))*MaxJogSpeed)));
                mc.mcJogSetRate(inst, RTHX_MapToMashineAxis, ((((tonumber(rthx)+DeadZone)/(100-DeadZone))*MaxJogSpeed)*-1));
                mc.mcJogVelocityStart(inst, RTHX_MapToMashineAxis, mc.MC_JOG_NEG);
                --mc.mcCntlSetLastError(inst, string.format("E_X360_RTH_X_DOWN (%s)", (((tonumber(rthx)+DeadZone)/(100-DeadZone))*MaxJogSpeed)));
            end
    end -- RIGHTHAND THUMB X-AXIS
---- LEFTHAND THUMB Y-AXIS
    local lthy = GetX360("LTH_Y_Val");
if (tonumber(lthy) >= (DeadZone*-1)) and (tonumber(lthy) <= DeadZone) then
        --mc.mcCntlSetLastError(inst, "X360_LTH_Y_CENTER_Begin");
        mc.mcJogSetRate(inst, LTHY_MapToMashineAxis, 0);
        mc.mcJogVelocityStop(inst, LTHY_MapToMashineAxis);
        --mc.mcCntlSetLastError(inst, "X360_LTH_Y_CENTER_end");
    else
            if lthy > "0" then
                --mc.mcCntlSetLastError(inst, string.format("B_X360_LTH_Y_UP (%s)", (((tonumber(rthx)-DeadZone)/(100-DeadZone))*MaxJogSpeed)));
                mc.mcJogSetRate(inst, LTHY_MapToMashineAxis, (((tonumber(lthy)-DeadZone)/(100-DeadZone))*MaxJogSpeed));
                mc.mcJogVelocityStart(inst, LTHY_MapToMashineAxis, mc.MC_JOG_POS);
                --mc.mcCntlSetLastError(inst, string.format("E_X360_LTH_Y_UP (%s)", (((tonumber(rthx)-DeadZone)/(100-DeadZone))*MaxJogSpeed)));
            elseif lthy < "0" then
                --mc.mcCntlSetLastError(inst, string.format("B_X360_LTH_Y_DOWN (%s)", (((tonumber(rthx)+DeadZone)/(100-DeadZone))*MaxJogSpeed)));
                mc.mcJogSetRate(inst, LTHY_MapToMashineAxis, ((((tonumber(lthy)+DeadZone)/(100-DeadZone))*MaxJogSpeed)*-1));
                mc.mcJogVelocityStart(inst, LTHY_MapToMashineAxis, mc.MC_JOG_NEG);
                --mc.mcCntlSetLastError(inst, string.format("E_X360_LTH_Y_DOWN (%s)", (((tonumber(rthx)+DeadZone)/(100-DeadZone))*MaxJogSpeed)));
            end
    end -- LEFTHAND THUMB Y-AXIS
---- LEFTHAND THUMB X-AXIS
    local lthx = GetX360("LTH_X_Val");
if (tonumber(lthx) >= (DeadZone*-1)) and (tonumber(lthx) <= DeadZone) then
        --mc.mcCntlSetLastError(inst, "X360_LTH_X_CENTER_Begin");
        mc.mcJogSetRate(inst, LTHX_MapToMashineAxis, 0);
        mc.mcJogVelocityStop(inst, LTHX_MapToMashineAxis);
        --mc.mcCntlSetLastError(inst, "X360_LTH_X_CENTER_end");
    else
            if lthx > "0" then
                --mc.mcCntlSetLastError(inst, string.format("B_X360_LTH_X_UP (%s)", (((tonumber(rthx)-DeadZone)/(100-DeadZone))*MaxJogSpeed)));
                mc.mcJogSetRate(inst, LTHX_MapToMashineAxis, (((tonumber(lthx)-DeadZone)/(100-DeadZone))*MaxJogSpeed));
                mc.mcJogVelocityStart(inst, LTHX_MapToMashineAxis, mc.MC_JOG_POS);
                --mc.mcCntlSetLastError(inst, string.format("E_X360_LTH_X_UP (%s)", (((tonumber(rthx)-DeadZone)/(100-DeadZone))*MaxJogSpeed)));
            elseif lthx < "0" then
                --mc.mcCntlSetLastError(inst, string.format("B_X360_LTH_X_DOWN (%s)", (((tonumber(rthx)+DeadZone)/(100-DeadZone))*MaxJogSpeed)));
                mc.mcJogSetRate(inst, LTHX_MapToMashineAxis, ((((tonumber(lthx)+DeadZone)/(100-DeadZone))*MaxJogSpeed)*-1));
                mc.mcJogVelocityStart(inst, LTHX_MapToMashineAxis, mc.MC_JOG_NEG);
                --mc.mcCntlSetLastError(inst, string.format("E_X360_LTH_X_DOWN (%s)", (((tonumber(rthx)+DeadZone)/(100-DeadZone))*MaxJogSpeed)));
            end
    end -- LEFTHAND THUMB X-AXIS
    end)
« Last Edit: November 27, 2016, 02:19:20 PM by Bx3mE »
Offline DazTheGas
  •  778 778
  • DazTheGas
« Reply #3 on: November 27, 2016, 03:46:11 PM »
Here`s a little snippet of what I use for buttons as remember if you turn on a button you also need to turn it off, that might help you on the way ;-)
Code: [Select]
local XPState = false
local XNState = false
local YPState = false
local YNState = false
    end
    X360_Panel:Connect(wx.wxEVT_TIMER, function (event)
-- Y++
if GetXin("DPad_UP") == "1" and YPState == false then
mc.mcSignalSetState (mc.mcSignalGetHandle (inst, mc.ISIG_JOGYP), 1)
YPState = true
end
if GetXin("DPad_UP") == "0" and YPState == true then
mc.mcSignalSetState (mc.mcSignalGetHandle (inst, mc.ISIG_JOGYP), 0)
YPState = false
end
-- Y--
if GetXin("DPad_DOWN") == "1" and YNState == false then
mc.mcSignalSetState (mc.mcSignalGetHandle (inst, mc.ISIG_JOGYN), 1)
YNState = true
end
if GetXin("DPad_DOWN") == "0" and YNState == true then
mc.mcSignalSetState (mc.mcSignalGetHandle (inst, mc.ISIG_JOGYN), 0)
YNState = false
end
-- X++
if GetXin("DPad_RIGHT") == "1" and XPState == false then
mc.mcSignalSetState (mc.mcSignalGetHandle (inst, mc.ISIG_JOGXP), 1)
XPState = true
end
if GetXin("DPad_RIGHT") == "0" and XPState == true then
mc.mcSignalSetState (mc.mcSignalGetHandle (inst, mc.ISIG_JOGXP), 0)
XPState = false
end
-- X--
if GetXin("DPad_LEFT") == "1" and XNState == false then
mc.mcSignalSetState (mc.mcSignalGetHandle (inst, mc.ISIG_JOGXN), 1)
XNState = true
end
if GetXin("DPad_LEFT") == "0" and XNState == true then
mc.mcSignalSetState (mc.mcSignalGetHandle (inst, mc.ISIG_JOGXN), 0)
XNState = false
end
end)
DazTheGas
Offline Bx3mE
  •  68 68
« Reply #4 on: November 27, 2016, 04:54:48 PM »
I can see that it would be good to avoid hammering the mc.mcSignal...()
Any other point?
Should i use mc.mcSignalSetState instead of mc.mcJogVelocityStart(inst, RTHY_MapToMashineAxis, mc.MC_JOG_POS); ????
Offline DazTheGas
  •  778 778
  • DazTheGas
« Reply #5 on: November 27, 2016, 05:26:19 PM »
By using the mcSignalSetState on the axis it gives me the advantage of using the same routine whether I am in cont or inc mode, by using mcJogVelocityStart you will have to write another routine for mcJogIncStart.
DazTHeGas
Offline Bx3mE
  •  68 68
« Reply #6 on: November 27, 2016, 08:28:06 PM »
GR8! Then it is the way i want it to be for now.
Adding Inc mode will be done later.......maybe.... :P
« Last Edit: November 27, 2016, 08:38:43 PM by Bx3mE »
Offline Bx3mE
  •  68 68
« Reply #7 on: November 27, 2016, 08:29:58 PM »
Some more progress...  ;D
Code: [Select]
---- CONFIG
    local DeadZone = 25 --Based on controller output value (-99 => 99)
    local MaxJogSpeed = 25 --Percentage of axix max speed
    local RTHY_MapToMashineAxis = mc.AXIS2 -- Z-AXIS
    local RTHX_MapToMashineAxis = mc.AXIS3 -- A-AXIS
    local LTHY_MapToMashineAxis = mc.AXIS1 -- Y-AXIS
    local LTHX_MapToMashineAxis = mc.AXIS0 -- X-AXIS
    local isPressed_BTN = {false,false,false,false} -- Buttons A,B,X,Y
-- FUNCTIONS
    end
    function EnableMashine(finst,pressed)
        if pressed then
            --I dont want to clear E-Stop on BTN_E-Stop_UP so instead i use X360´s MashineEnable for it...
            mc.mcSignalSetState (mc.mcSignalGetHandle (finst, mc.ISIG_EMERGENCY), 0);
            mc.mcCntlEnable(finst, true)
        else
            mc.mcCntlSetLastError(finst, "X360_Enabled_Machine")
        end
        return
    end
    function CycleStart(finst,pressed)
        if pressed then
            mc.mcCntlCycleStart(finst)
        else
        end
        return
    end
    function EStop(finst,pressed)
        if pressed then
            mc.mcSignalSetState (mc.mcSignalGetHandle (finst, mc.ISIG_EMERGENCY), 1);
        else
            -- Moved to EnableMashine
            --mc.mcSignalSetState (mc.mcSignalGetHandle (finst, mc.ISIG_EMERGENCY), 0);
        end
        return
    end
    function HandleButtonPress(finst,btn,btnNo,func,msg)
        if btn == "1" and isPressed_BTN[btnNo] == false then
            func(finst,true)
            mc.mcCntlSetLastError(finst, msg)
            isPressed_BTN[btnNo] = true
        end
        if btn == "0" and isPressed_BTN[btnNo] == true then
            func(finst,false)
            isPressed_BTN[btnNo] = false
        end
        return
    end
    function HandleThumbInput(finst,th,axis, isSecured,DZ, MaxJS)
        if (tonumber(th) >= (DZ*-1)) and (tonumber(th) <= DZ) then
            mc.mcJogSetRate(finst, axis, 0)
            mc.mcJogVelocityStop(finst, axis);
        else
            if isSecured then
                if tonumber(th) > tonumber(DZ) then
                    mc.mcJogSetRate(finst, axis, (((tonumber(th)-DZ)/(100-DZ))*MaxJS))
                    mc.mcJogVelocityStart(finst, axis, mc.MC_JOG_POS)
                elseif tonumber(th) < (tonumber(DZ)*-1) then
                    mc.mcJogSetRate(finst, axis, ((((tonumber(th)+DZ)/(100-DZ))*MaxJS)*-1))
                    mc.mcJogVelocityStart(finst, axis, mc.MC_JOG_NEG)
                end
            end
        end
        return
    end
    local isSecured = (GetX360("Btn_RS") == "1" ) and (GetX360("Btn_LS") == "1" )
-- HANDLE E-STOP ON BTN_B
    HandleButtonPress(inst,GetX360("Btn_B"),2,EStop,"X360_E-STOP")
-- HANDLE ALL OTHER BUTTONS
    if isSecured then
        -- MASHINE ENABLE ON BTN_X
        HandleButtonPress(inst,GetX360("Btn_X"),3,EnableMashine,"X360_Enabled_Machine")
        -- CYCLE START ON BTN_A
        HandleButtonPress(inst,GetX360("Btn_A"),1,CycleStart,"X360_CycleStart")
    end
-- HANDLE THUMBSTICKS
    HandleThumbInput(inst,GetX360("RTH_Y_Val"),RTHY_MapToMashineAxis,isSecured, DeadZone, MaxJogSpeed)
    HandleThumbInput(inst,GetX360("RTH_X_Val"),RTHX_MapToMashineAxis,isSecured, DeadZone, MaxJogSpeed)
    HandleThumbInput(inst,GetX360("LTH_Y_Val"),LTHY_MapToMashineAxis,isSecured, DeadZone, MaxJogSpeed)
    HandleThumbInput(inst,GetX360("LTH_X_Val"),LTHX_MapToMashineAxis,isSecured, DeadZone, MaxJogSpeed)
    end)
« Last Edit: November 27, 2016, 08:45:55 PM by Bx3mE »
Offline Bx3mE
  •  68 68
« Reply #8 on: November 27, 2016, 08:47:18 PM »
I am having one issue... Pressing the X-Button will only do machine enable the second time i press it..??? Do you know how this can be?
Offline Bx3mE
  •  68 68
« Reply #9 on: November 28, 2016, 03:16:53 AM »
Ok... I added a sleep and it does the trick...
