Hello Guest it is October 24, 2026, 11:40:32 AM
Author Topic: UC-100 and Mach4  (Read 14475 times)
UC-100 and Mach4
« on: August 14, 2016, 09:00:57 PM »
Hi, will a UC-100 work with Mach4?  Also can I upgrade Mach3 to Mach4?
Re: UC-100 and Mach4
« Reply #1 on: August 14, 2016, 09:15:23 PM »
At this time the UC-100 is advertized as supporting only Mach3.
PMDX offers a similar device for Mach4. See:
http://www.pmdx.com/PMDX-411
Mach4 is considered a new product and no credit is given for an upgrade from Mach3.
Steve Stallings
www.PMDX.com
« Reply #2 on: August 15, 2016, 05:10:21 AM »
Would I need a plugin for running straight to the parallel port from my breakout board?  With Mach 3 I have to have the UC100.
« Reply #3 on: August 15, 2016, 05:31:39 AM »
Yes, to run a parallel port device from Mach4 you need the legacy plug-in. See:
http://www.machsupport.com/shop/parallel-port-legacy-plugin-for-mach4/
There a few things to keep in mind when using this plug-in:
1) It requires that the operating system be 32 bit. A 64 bit system will not work.
2) The operating system must be Windows 7 or older. Win8 and Win10 will not work.
3) Lathe threading and plasma cutters with Mach4 doing the THC are not supported.
4) There are no plans to enhance this plug-in later.
Steve Stallings
www.PMDX.com
« Reply #4 on: August 15, 2016, 06:02:52 AM »
Ok my system is 64bit.
« Reply #5 on: August 15, 2016, 06:50:26 AM »
Will Mach3 run 5 axis independently without pairing axis?
  •  9,374 9,374
« Reply #6 on: August 15, 2016, 07:00:23 AM »
Yes it will.
« Reply #7 on: August 17, 2016, 06:10:26 PM »
Looks like the pmdx only supports 4 axis.  I need 5 axis support.
  •  9,374 9,374
« Reply #8 on: August 18, 2016, 01:16:56 AM »
Perhaps take a look at the ESS http://warp9td.com/
That will work 5 axis with either Mach3 or Mach4.
