Hello
Guest
it is
November 13, 2026, 11:29:36 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Cutting to deep
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Cutting to deep (Read 11767 times)
Jimchi52
53
Cutting to deep
on:
August 14, 2016, 01:12:03 PM »
I have my program set to cut .0625 and it is cutting .125. Any ideas?
Logged
kolias
1,165
Re: Cutting to deep
Reply #1 on:
August 14, 2016, 01:52:16 PM »
How did you establish the Z axis 0 point of your work surface?
Logged
Nicolas
Jimchi52
53
Re: Cutting to deep
Reply #2 on:
August 14, 2016, 01:57:14 PM »
Set my cutter on my job I am cutting
Logged
kolias
1,165
Re: Cutting to deep
Reply #3 on:
August 15, 2016, 08:38:58 AM »
When you say "I have my program set to cut .0625....", what program is this? Is it a script?
If yes, can you please post the script?
In addition, when you say "Set my cutter on my job I am cutting", do you do this manually or with a probe?
Logged
Nicolas
Jimchi52
53
Re: Cutting to deep
Reply #4 on:
August 15, 2016, 09:07:00 AM »
Vetric pro
Set cutter down manually to top of my stock then 0 it
Logged
kolias
1,165
Re: Cutting to deep
Reply #5 on:
August 15, 2016, 12:37:01 PM »
To my opinion, this is not a very accurate way to set your Z axis. I have attach a .doc which I got from the web some time ago and describes how to make a very inexpensive touch probe and I have it on my machine and always works. Instead of the PCB board I use a 1/4" aluminum flat bar but you can use whatever you want. Make sure you change the scrip to reflect the thickness of your material and always have your hand on the Estop when you Autozero the Z axis
Logged
Nicolas
Jimchi52
53
Re: Cutting to deep
Reply #6 on:
August 15, 2016, 12:38:36 PM »
I have a zero plate I bought awhile back but did not know how to set it up
Logged
Print
Pages:
1
Go Up
« previous
next »
