Hello Guest it is September 28, 2026, 11:18:23 PM
Author Topic: Need 5-axis screen for my micro 5-axis CNC  (Read 24740 times)
« on: August 12, 2016, 09:09:34 PM »
Hi all,  I built a tiny 5-axis CNC that I want use Mach3 to control.  The 6-axis that Artsoft has for download is missing most of the buttons and I think it must be non compatible with Windows 7.  Does anyone know where to get a 5-axis screen that actually works?
  •  9,374 9,374
Re: Need 5-axis screen for my micro 5-axis CNC
« Reply #1 on: August 13, 2016, 01:19:16 AM »
Download the 6 axis screen http://www.machsupport.com/software/downloads-updates/screensets/
Unzip the folder.
Copy the file 6axis.set into your Mach3 folder.
Copy the folder UT Buttons-JPG into your Mach3 / Bitmaps / MillBitmaps folder.
If you do it correctly then you will have all the buttons  ;)
« Reply #2 on: August 13, 2016, 08:21:43 AM »
That worked thank you so much.
