Hello Guest it is November 13, 2026, 02:54:18 PM
Author Topic: Homing  (Read 35773 times)
Re: Homing
« Reply #20 on: August 09, 2016, 03:10:22 PM »
Index debounce is for  the index input for a spindle, not homing.
Re: Homing
« Reply #21 on: August 09, 2016, 03:52:22 PM »
How can I make it come farther away from the limit switch in z when I ref home
Re: Homing
« Reply #22 on: August 09, 2016, 06:22:45 PM »
It only backs up until the switch opens, unless the motion controller plugin has a settting for backing off.
The KL 4030 is a stepper drive, not a motion controller. Which motion controller are you using?
Re: Homing
« Reply #23 on: August 09, 2016, 06:26:37 PM »
? I don't know I didn't build the cnc. I got it working goog so far I had to increase the debounce to 8500 seems to be working fine now
Re: Homing
« Reply #24 on: September 03, 2016, 03:59:39 PM »
there is a option in config/home-soft limits that I suppose can
"make it come farther away from the limit switch in z when I ref home "
i think its called "home off"
Offline Davek0974
  •  2,606 2,606
Re: Homing
« Reply #25 on: September 04, 2016, 02:07:57 AM »
No thats not what it does, Home Offset merely tells the machine where you want home to be relative to the switches.
My milling machine home switches are about 100mm in from the actual home position so i have a -100mm home offset.
The move away from the switch itself during homing is internal and based upon the switch itself - Mach will move to the switch until it triggers, stop, move away until it opens - that is the home point, it will then stop.
Re: Homing
« Reply #26 on: September 04, 2016, 07:23:43 AM »
thanks for clearing that up :)
