Hello Guest it is October 30, 2026, 01:05:04 PM
Author Topic: Homing  (Read 35173 times)
Re: Homing
« Reply #10 on: August 08, 2016, 09:00:24 PM »
Ah, thanks Gerry!  I was at a loss at this point.  Debounce could very well do it.
Re: Homing
« Reply #11 on: August 09, 2016, 04:21:03 AM »
I tried that and it works then I go to try it again and it doesn't
Re: Homing
« Reply #12 on: August 09, 2016, 04:22:22 AM »
The  x and y work fine  it is just the z axis
Re: Homing
« Reply #13 on: August 09, 2016, 05:31:19 AM »
Then set it to a higher value.
What did you set it to?
You either have noise, or a bad switch.
Re: Homing
« Reply #14 on: August 09, 2016, 07:05:44 AM »
The switch is good I tried 1 2 3 4 5 works best at 4 but 1 time it will work the next time it doesn't. I upgraded from windows 7 which it worked fine then I upgraded to windows 10 now it doesn't.
Re: Homing
« Reply #15 on: August 09, 2016, 10:34:48 AM »
So you're using a motion controller? Which one. The Debounce in General Config has no effect with a motion controller.
Re: Homing
« Reply #16 on: August 09, 2016, 11:09:36 AM »
K 4030 Kelinger tec
Re: Homing
« Reply #17 on: August 09, 2016, 11:12:12 AM »
When I set the index debounce to 4 it works the best. It will work once then not work
Re: Homing
« Reply #18 on: August 09, 2016, 02:34:20 PM »
Yep, sounds like the switch is acting flakey.  Can you swap the upper and lower limit switches to see if that works better?  If not, try doing a "Home Negative" and check if that operates properly.  (CAUTION: Homing to a negative Z requires careful monitoring and quick response on the RESET button if things go awry!)
Re: Homing
« Reply #19 on: August 09, 2016, 02:49:32 PM »
Thank god that's it hope I got another one
