Hello Guest it is November 23, 2026, 09:47:28 PM
Author Topic: single block  (Read 20042 times)
Offline MarkC
  •  94 94
single block
« on: November 10, 2005, 12:43:03 PM »
I have a problem with single block not working or doing wierd stuff. Last nite I clicked single block, let it come down near part & looked away at screen for a bit. It started cutting when I was not ready for it and kept on going, block after block. I clicked single block off then on and it stopped at the end of the next block as it should. Then later I clicked it near the end of a toolpath in preparation to check the next move and it took off, at least AWAY from the part. It did this during an arc out of a contour. I restarted and it worked as it should. I had this problem a lot with Mach 2 and now it's doing it with Mach 3(v 1.83.012 I think).
Any ideas?
Mark
Mark
Re: single block
« Reply #1 on: November 10, 2005, 07:46:54 PM »
Not sure, but this sounds like maybe a noise issue or something running in the background and glitching Mach. I had MAch2 do that one time only. It was on single block, middle of a program and it just proceeded the next block all on it's own. I stripped the PC of all the VIrus software etc. and it never happened again. Quick-time movie player is one of the worst to interfere. Get rid of all that stuff if you have it. Get the optimisation.txt from the Mach yahoo usergroup files.
Ron
Offline MarkC
  •  94 94
Re: single block
« Reply #2 on: November 10, 2005, 07:55:39 PM »
Will look at anything that could be contributing & get optimizing file
Mark
Mark
BONE
Re: single block
« Reply #3 on: June 04, 2006, 02:21:18 PM »
I had a similar problem last night.  Running in program and single blocked program on a contour.  Finished contour then stopped.  Then I hit cycle start and it decide to do a loop first then take off scraping a 5 hour run part.  Very bummed.
Any information about that.
BONE
