Hello Guest it is November 13, 2026, 02:17:11 PM
Author Topic: Tool Offset Macro...  (Read 222254 times)
Offline rcaffin
  •  1,073 1,073
Re: Tool Offset Macro...
« Reply #150 on: August 21, 2016, 07:06:36 AM »
Good God Emily!
You steam train enthusiasts are stark raving mad ...
Impressive thing. I take it one can ride on the carriages at Open Days at the local Club Meets? There's a club nearby which does that, but I suspect theirs is 1/4 scale.
Blimey.
Chers
Roger
Offline Davek0974
  •  2,606 2,606
« Reply #151 on: August 21, 2016, 07:23:05 AM »
That engine would easily pull a cart with 6-8 adults on plus water and coal around a rally field;)
Rail based stuff is a different scaling designation but just as powerful, steam is a wonderful thing:)
Offline rcaffin
  •  1,073 1,073
« Reply #152 on: August 21, 2016, 07:35:09 AM »
Um - I think theirs is on railway track. They have some permanent ways there.
Roger
Offline Davek0974
  •  2,606 2,606
« Reply #153 on: August 24, 2016, 08:54:40 AM »
still waiting for parts but got a reply from Cs-Labs today, they reckon its not the correct way of doing stuff - using an axis input and Mach DRO BUT cant see why it wouldn't work :)
Seems i should be using the ENC module channels 2 or 3 for this.
Will have to see what happens before spending more. Got the linear motion part built and fitted the encoder, just waiting on the line-driver now.
Offline Davek0974
  •  2,606 2,606
« Reply #154 on: August 24, 2016, 11:09:46 AM »
Ok, line-driver IC just arrived, will get it wired tomorrow morning as its stupid-hot in the shop now.
I gather its just inputs on 1A, 2A, 3A and outputs on 1Y/1Z, 2Y/2Z, 3Y/3Z with a 0.1uf on the supply rails?
Ignore the G input which i presume is a gate?
Ignore unused 4th input?
« Reply #155 on: August 24, 2016, 04:18:45 PM »
From memory you need to connect the G to 5v or the G- to 0v depending on which way you want to have the output with regards the Hi or Lo of the input pulse.
Offline rcaffin
  •  1,073 1,073
« Reply #156 on: August 24, 2016, 04:26:46 PM »
Just don't leave any unused inputs floating.
Roger
Offline Davek0974
  •  2,606 2,606
« Reply #157 on: August 25, 2016, 02:08:41 AM »
Ok, so G has to go one way but in this case it won't matter which way ?
And tie unused inputs to 0v.
Offline rcaffin
  •  1,073 1,073
« Reply #158 on: August 25, 2016, 02:14:19 AM »
If you are not using the G outputs ... where input goes does not matter.
Offline Davek0974
  •  2,606 2,606
« Reply #159 on: August 25, 2016, 02:26:08 AM »
Just had another look, there are no G outputs, its internal and used to flip the outputs into a third state of "off", looks like for logical use G needs to go high.
