Hello Guest it is November 13, 2026, 09:44:36 AM
Author Topic: Tool Offset Macro...  (Read 222064 times)
Offline rcaffin
  •  1,073 1,073
Re: Tool Offset Macro...
« Reply #120 on: August 20, 2016, 02:46:53 AM »
They work well, but you need to mount them right at the encoder for best effect.
Single-ended encoder signals in - you may need pull-up resistors there.
Differential output: you will need screened 8-core cable from the encoder to the driver. 2 wires for power and ground, 2 wires for A, 2 for B and 2 for I.
Put a 0.1 uF cap across the supply at the chip.
Roger
Offline Davek0974
  •  2,606 2,606
« Reply #121 on: August 20, 2016, 03:02:17 AM »
just found this from Hood in the past on his Beaver Mill, looks like it really is that simple.
https://www.machsupport.com/forum/index.php?action=dlattach;topic=21149.0;attach=29905;image
The encoder only has 1m lead on it so that can be shortened a bit, got a chip on its way, already got vero board and plenty of caps etc, sounds like a project coming on :)
« Last Edit: August 20, 2016, 03:08:24 AM by Davek0974 »
Offline rcaffin
  •  1,073 1,073
« Reply #122 on: August 20, 2016, 03:09:21 AM »
You will also find little screw connectors at RSComp, as shown here. They are really very nice - beats the hell out of soldering the wires to pads on the board. And you can stick the voltmeter probe on the recessed screw heads as well.
The central PCB is actually 3 encoders' worth of optical isolation. It may be overkill - or it may not.
Roger
« Reply #123 on: August 20, 2016, 03:56:18 AM »
Personally I think I would just solder direct to the line driver for this application as it will be right at the encoder and can probably be housed inside or even taped direct to the body of the encoder.
Offline rcaffin
  •  1,073 1,073
« Reply #124 on: August 20, 2016, 04:16:21 AM »
Well, yes, that is another way of doing it.
My concern is that every time I do something like that, the chip dies and it is then a huge hassle replacing it. Murphy!
Roger
« Reply #125 on: August 20, 2016, 04:19:00 AM »
One word,
Socket :)
Offline rcaffin
  •  1,073 1,073
« Reply #126 on: August 20, 2016, 04:26:26 AM »
Oh, for sure. Until I get into the surface-mount devices. Some of the stuff seems to be only available these days as SMDs.
Roger
« Reply #127 on: August 20, 2016, 04:29:09 AM »
Yes, smd is the future or suppose really the present, sadly my eyes are not the past :D
Here is a wee board I made up using the sockets, it was before the CSMIO days so had to convert the Step/Dir to differential. I got a few boards printed, was needing it for use with the Scorpion board I was testing at the time, big brother of the ESS I suppose.
Offline rcaffin
  •  1,073 1,073
« Reply #128 on: August 20, 2016, 05:01:53 AM »
I like.
Getting PCBs made locally is a bit more $$. So I engrave my own using double-sided laminate. Earth on top side, tracks the other.
I do it on a vacuum table. Not as smooth-looking as yours.
Roger
« Reply #129 on: August 20, 2016, 05:46:50 AM »
Yes, works well, did that for a prototype I was designing for a customer.
