Hello Guest it is October 22, 2026, 11:48:16 PM
Author Topic: Machine setup help - urgent if possible :)  (Read 55102 times)
Offline Davek0974
  •  2,606 2,606
Re: Machine setup help - urgent if possible :)
« Reply #40 on: July 28, 2016, 01:15:57 AM »
Thats the odd part - there is nothing i can find that touches that DRO so it must be an internal thing linked to pulley numbers or something.
Is there an OEMbutton code for the spindle speed override button - maybe easier to just tack that on at the end??
« Reply #41 on: July 28, 2016, 01:44:58 AM »
DoOemButton(183)
I seem to recall however that years ago I had issues using that button in a macro on the Beaver mill and ended up writing to the DRO itself, so if there are problems you could try.
SetOemDRO(74,100)
If however you have a pot and have the IP-A set to control the override itself rather than allowing Mach to, then likely it will force it to 100% anyway.
Offline Davek0974
  •  2,606 2,606
« Reply #42 on: July 28, 2016, 01:57:41 AM »
yes i too tried button 183 and it was not happy.
I will have a pot on the CSMIO so maybe that will fix it as you say, writing to the DRO could be useful too if not.
Offline Davek0974
  •  2,606 2,606
« Reply #43 on: July 29, 2016, 02:06:57 AM »
Sorted :)
With the help of a much admired friend ;) I now have it working properly.
You have to have two pulleys only,
1= 1 to 3000 rpm reversed
2 = 1 to 3000rpm normal
Using my modified macro attached to instruct which mechanical setting to use, there is now no funky spindle speed override display :)
Offline Davek0974
  •  2,606 2,606
« Reply #44 on: July 31, 2016, 09:47:12 AM »
Ignore the last post, it worked on the simulation but not in reality as the PWM was totally freaked out!
I have gone back to my code with the screwy SSO DRO stuff, i also fitted the SSO pot so the CSMIO had control - it certainly fixes the weird SSO behaviour BUT the range of the override pot is very limited and dependant on the pulley setting - very complex relationship between pulleys, wpm and SSO pot i think.
Still it all seems to play together now, pretty smoothly.
