Hello Guest it is November 22, 2026, 07:53:23 PM
Author Topic: OEM trigger quantity  (Read 11489 times)
« on: July 19, 2016, 01:42:39 AM »
Hi everyone,
Recently I got a Ethernet smoothstepper which can support more inputs and outputs for use. I have and pendant and other external devices like toolchanger that totally need more than 15 oem triggers to be operated. Does anybody know how many this triggers exactly are available in Mach3? If there is not enough, how can I operate those extra devices?
Thanks in advance.
  •  9,378 9,378
Re: OEM trigger quantity
« Reply #1 on: July 19, 2016, 05:39:08 AM »
Within Mach3 there are 20 user definable Output# available (plus 10 others).
« Reply #2 on: July 19, 2016, 08:14:08 AM »
How about user-define inputs, my pendant consumed 10 oem trigger inputs, i need 13 more these inputs for other use. Is it available in Mach3? For hardware,  they are available because the 2nd and 3rd ports' 2-9 pins can be configured as inputs.
  •  9,378 9,378
« Reply #3 on: July 19, 2016, 10:08:14 AM »
Check out Config / Ports & Pins / Input Signals.
« Reply #4 on: July 19, 2016, 12:49:33 PM »
With the smooth stepper you will need to enable ports 2 and 3 as inputs, within the plugin config, ess configuration settings too.
If after all that you don't have enough inputs... you can add a Pokeys too....
Rob
« Reply #5 on: July 19, 2016, 01:43:31 PM »
In Mach3 configure input and output page, for user-define use, there are 15 oem trigger inputs and 4 separate inputs. Are they the alll the quantity that are for user to define the corresponding ports and pins on the hardware?
