Hello Guest it is November 13, 2026, 10:33:55 PM
Author Topic: Soft limits enable Auto limit override  (Read 13068 times)
« on: July 18, 2016, 02:02:48 PM »
Hello,
I use PoKeys57CNC with 4 axis and a switch for each axis.
When the limit is triggered and I press the reset button,
I cannot move the motors (like in picture 1).
If I check shared with limit+, then Auto limit OverRide is activated and I can then move the motors to get out of the limit zone (picture 2).
I cannot save this. When I restart Mach3 I have to repeat those steps to check shared with limit+. Auto limit OverRide is activated in Mach3.
What should  I do?
Thanks!
Offline NeoTO
  •  504 504
    • PoLabs
Re: Soft limits enable Auto limit override
« Reply #1 on: July 18, 2016, 02:55:54 PM »
Manual limit override in Mach3 should temporarily disable the limits. We will check this.
Matevž, PoLabs
www.poscope.com home of PoKeys USB HID, IO, USB, Ethernet controler and PoScope USB PC oscilloscope
« Reply #2 on: July 19, 2016, 10:59:30 AM »
Ok working properly, we upgrade the firmware.
