Third party software and hardware support forums. => PoKeys => Topic started by: fane on July 18, 2016, 03:02:48 PM
Hello,
I use PoKeys57CNC with 4 axis and a switch for each axis.
When the limit is triggered and I press the reset button,
I cannot move the motors (like in picture 1).
(http://)
If I check shared with limit+, then Auto limit OverRide is activated and I can then move the motors to get out of the limit zone (picture 2).
(http://)
I cannot save this. When I restart Mach3 I have to repeat those steps to check shared with limit+. Auto limit OverRide is activated in Mach3.
What should I do?
Thanks!
Manual limit override in Mach3 should temporarily disable the limits. We will check this.
Matevž, PoLabs
Ok working properly, we upgrade the firmware.
