Hello Guest it is October 12, 2026, 01:20:28 AM
Author Topic: Problem with Z-Axis Reversal when Soft Limits Active  (Read 8063 times)
Offline $cott
  •  36 36
« on: July 09, 2016, 05:37:16 PM »
I am using Mach4 with ESS and a Leadshine MX4660 driver.  I have got xyz axis's set up with hall detectors and when I reference all or any individuale axis they home properly each time.  Yet when I activate the Soft Limits button the directions of X-axis and Y-axis work fine but the Z-axis reverses direction when I press a plus or minus jog button.  Can some one explained to me what I have done wrong to have the Z-axis reverse movement directions when the Soft Limit button is active.
Scott
Offline $cott
  •  36 36
Re: Problem with Z-Axis Direction when Soft Limits Active
« Reply #1 on: July 09, 2016, 06:15:25 PM »
Need to correct my problem statement the z-axis only goes in up ward direction when soft-limits is active!
No matter if i push the plus or minus button it always goes positive or up ward.
Sorry just wanted to make sure i have this right.
Scott
Re: Problem with Z-Axis Reversal when Soft Limits Active
« Reply #2 on: July 09, 2016, 08:15:00 PM »
This is a quirk of how the soft limits react if the setup has some values in the wrong place.
See this thread:
http://www.machsupport.com/forum/index.php/topic,31326.0.html
Steve Stallings
www.PMDX.com
Steve Stallings
www.PMDX.com
Offline $cott
  •  36 36
« Reply #3 on: July 09, 2016, 10:21:06 PM »
Perfect Thanks Steve and Bob .... as usual you guys at PMDX are the best!
Scott
