Hello Guest it is November 19, 2026, 08:45:23 AM
Author Topic: Mach3 crashes using LPT but not USB  (Read 13106 times)
Offline Rimmel
  •  284 284
« on: July 01, 2016, 04:55:12 AM »
Hi, I until recently have been using a UC100 usb notion controller. However due to technical problems have had to go back to using the LPT1 port.
When using the USB I could leave the mahine on for days or weeks without a single problem, howveer since changing to back the LPT1 the WinXP machine crashes (locks up completely) at least once every 24 hours.
Using:
Mach3  062
LPT1 0x378  ECP mode
25000hz
Anuy ideas?
thanks
Rimmel
Offline Rimmel
  •  284 284
Re: Mach3 crashes using LPT but not USB
« Reply #1 on: July 01, 2016, 05:18:10 AM »
Aditionally - I have changed absolutely nothing else! Literally a switch between USB and LPT1
  •  9,378 9,378
« Reply #2 on: July 01, 2016, 06:11:49 AM »
Perhaps try running the DriverTest (Mach3 folder) and see what kind of results you get.
Offline Rimmel
  •  284 284
« Reply #3 on: July 01, 2016, 06:51:17 AM »
Hi sorry mean't to say the drivertest comes back perfectly with an excellent result.
I was wondering what the recommended settings were for the LPT port? e.g ECP, EPP using an interrupt or not?
thanks
  •  9,378 9,378
« Reply #4 on: July 01, 2016, 06:58:45 AM »
I think it's a matter of if it works then it works.
« Reply #5 on: July 01, 2016, 07:16:57 AM »
Probably won't help but worth a try I suppose, go to your plugin folder and remove any plugins you do not require, especially the one from the previous controller.
Alternatively rename the plugin folder to something like OldPlugins and then create a new (empty ) folder called Plugins.
Offline Rimmel
  •  284 284
« Reply #6 on: July 01, 2016, 07:26:06 AM »
Hi - I've already removed all the plugins except the Flash-Flashscreen plugin (is that needed?). Never had any apart from the UC100 - and that is gone now
I heard there was a list of compatible PCI LPT cards, anyone know where? I might try adding one.
thanks
« Last Edit: July 01, 2016, 07:31:33 AM by Rimmel »
« Reply #7 on: July 05, 2016, 07:30:00 AM »
Check if you lose position, see the axis of the motor and check the angle be correct, make a mark.
If you lose position then is entering noise for the cable paralell, the mach3 then receive alarm of servo for crashing, check his shielding
Because change a parallel port, Which problem technical you have?
Renato
