Hello Guest it is November 22, 2026, 07:06:53 PM
Author Topic: X axis automatically reversing during Jog  (Read 9352 times)
« on: June 30, 2016, 12:02:33 PM »
I am running Mach3 on a Taig mill. I have just set it up. It appears that my Y and Z motors are working OK but when I jog the X in either direction it will only turn the axis a small distance and then automatically changes direction
I need help
  •  9,378 9,378
Re: X axis automatically reversing during Jog
« Reply #1 on: June 30, 2016, 11:55:58 PM »
As a first step I suggest you check your wiring, in particular, the wire that connects the X axis Direction signal between the PC and the axis driver.
« Reply #2 on: July 01, 2016, 08:36:08 AM »
Thanks Twe.akie
The X motor rapidly reverses even when it is removed from the drive. I swapped the serial port with no luck. When I swapped the Y motor with the X motor I found that the table was very hard to move even with the manual crank and the Y motor really labored.  I saw no breaks or damaged wires so maybe I fried the motor because the the table was so tight.
I there an adjustment I can make to free up the table? Is the one brand of motor that is better than another?
Thanks.
« Reply #3 on: July 01, 2016, 08:51:06 AM »
I just read about adjusting the Gib. How do you know when it is not too loose?
