Hello
Guest
it is
November 22, 2026, 07:10:39 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
DRO'S
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: DRO'S (Read 8581 times)
PCH
80
DRO'S
on:
June 27, 2016, 03:26:52 PM »
My pc did an upgrade to windows 10 and now dro's show movement but
the cnc does not respond when I jog.
Should I revert back to Windows 7 or is there a fix for Windows 10?
Logged
mc
384
Re: DRO'S
Reply #1 on:
June 27, 2016, 03:40:11 PM »
If you are using the parallel port, then you'll need to revert to Windows 7 (32bit).
If you're using an external motion controller, then you'll need to check you have a signed driver suitable for Windows 10.
Logged
PCH
80
Re: DRO'S
Reply #2 on:
June 27, 2016, 03:45:11 PM »
Just got that figured out. I did revert back as I do have a parallel port.
thanks for getting back to me
Logged
Print
Pages:
1
Go Up
« previous
next »
