Hello Guest it is October 24, 2026, 06:47:25 PM
Author Topic: Mach4 probe setup and use  (Read 19707 times)
« on: June 25, 2016, 08:46:32 AM »
Does anyone know where I can get information about calibrating and us sing a probe in mach4? Is there a place to enter the information about the probe tip?
Re: Mach4 probe setup and use
« Reply #1 on: June 27, 2016, 02:13:12 PM »
In the probing tab there is a calibration tab. Calibrate XY offset I think is what your looking for. In all of the probing pages there are help buttons. Each different help button displays different information.
Alternately, you could install the prerelease mentioned here http://www.machsupport.com/forum/index.php/topic,27039.msg227697.html#msg227697 and give the new touchoff module a go.
There aren't any docs to speak of for the module yet but hovering over elements (buttons, input fields, descriptions, etc.) in the touchoff gui shows tooltips that pretty much cover everything.
Offline dude1
  •  1,253 1,253
« Reply #2 on: June 27, 2016, 03:00:30 PM »
Chaoticone the module works with the ESS. but there are big problems with 3112 more testing today
« Reply #3 on: June 27, 2016, 05:34:07 PM »
Thanks for letting me know. Let me know how you get on.
Offline dude1
  •  1,253 1,253
« Reply #4 on: June 27, 2016, 06:30:20 PM »
the sim plug is making it E stop on a - axis move, any axis will do it, once or many times in a row
Offline royce
  •  40 40
« Reply #5 on: June 28, 2016, 04:02:04 PM »
I haven't had any problems with ESS Build 185 & Mach 3112 just a FYI.
Bridgeport Series 1 Rigid Ram Retrofitted w/PMDX126 BOB, PMDX107, Hitachi WJ200 VFD,ESS, Leadshine DM2282 Drivers running Mach4 comfortably.
« Reply #6 on: June 28, 2016, 08:20:38 PM »
Thanks for the feedback Royce.
Offline Stuart
  •  311 311
« Reply #7 on: June 29, 2016, 04:58:47 AM »
Same here a new virgin install of the pre release Mach4 and the 185 ESS working fine here on windows 10 Pro
Reading back through the posts above it looks like its a problem with the sim plugin which I have not tried so I cannot comment
Stuart
FYI this is a new controls fit consisting of a ESS and C25 because the ( Leafboy card was doing some funny things )
Offline dude1
  •  1,253 1,253
« Reply #8 on: June 29, 2016, 05:46:44 AM »
yep it was the sim plug
Offline Stuart
  •  311 311
« Reply #9 on: June 29, 2016, 05:49:15 AM »
Take a look in the ftp site 3113 is there bit smaller than 3112
Re the sim glad that was it
Stuart
