Hello Guest it is October 20, 2026, 09:46:20 PM
Author Topic: Jog Buttons reversed in Mach 3 after crashing Y axis  (Read 22856 times)
Offline rcaffin
  •  1,073 1,073
Re: Jog Buttons reversed in Mach 3 after crashing Y axis
« Reply #10 on: June 26, 2016, 07:49:08 PM »
It's been fun. Once a researcher, always a researcher. It gets in the blood.
LENR - any relation to cold fusion?
Mach3 will run on W7 with an ESS, at least the 32 bit version. That's my system right now. But I am not aware of any reasons why it should not run on the 64 bit version IF you use the ESS.
Roger
Offline GENX
  •  16 16
« Reply #11 on: June 26, 2016, 08:05:15 PM »
LENR -  CF Yes.
There has been no way to systemically control the reactions, but I do believe I have a novel process to manipulate them and thereby create a repeatable amount of energy.
 By taking the elements to mono-atomic form, re-synthesize them and "instruct" them where to recombine,mother nature will make the magic happen.
I was having trouble with my W7 64bit so I decided to use XP. I have not given up on trouble shooting it, just seemed superfluous since I had an XP OS ready to go.
Offline rcaffin
  •  1,073 1,073
« Reply #12 on: June 26, 2016, 08:07:38 PM »
I am sure that catalysts of some sort or other will be key if it going to work.
Roger
