Hello Guest it is October 21, 2026, 09:46:44 AM
Author Topic: Motor Drivers Current Settings  (Read 8047 times)
Offline kolias
  •  1,165 1,165
« on: June 20, 2016, 08:37:57 AM »
I have 4 KL-5056 drivers rated at 20-50VDC, 5.6A. Available current settings with their DIP switches are 3.2A, 3.8A, 4.3A, 4.9A, and 5.6A
My motors are KL23H2100-35-4B, rated voltage 2.55, current 3.5A
Which current setting should I choose on the drivers?
Nicolas
Re: Motor Drivers Current Settings
« Reply #1 on: June 20, 2016, 04:18:47 PM »
 I would set your drivers to the nearest  current setting without going over. so I think it would be 3.2.
Regards
Charlie M.
Offline kolias
  •  1,165 1,165
« Reply #2 on: June 20, 2016, 07:10:27 PM »
I was thinking to use the setting you mentioned Charlie but I was able to contact the supplier and he said to use 3.8A. There is also a DIP switch (#4) which in position OFF supplies half the current and position ON supplies full current; he said that for axes Y,A,X to set this switch to OFF and for the Z axis to set it to ON. I will expirement with this settings over the weekend and post the results for the benefit of other members
Thanks for your timre
Nicolas
