Hello Guest it is November 01, 2026, 10:12:57 AM
Author Topic: Zoom box  (Read 16060 times)
Zoom box
« on: May 23, 2007, 02:02:56 AM »
Hi Brian
Just a litle report.
If i select ZOOM BOX on the right side of the screen and i hit with the left mouse button one's , a point on the screen (without moving the mouse) my image is disappeared.
Greetings:
W.Jansen
Offline klmark
  •  107 107
Re: Zoom box
« Reply #1 on: May 23, 2007, 11:23:33 AM »
Hi
 Hold down the left mouse button and drag across the part you want to zoom in.That should work
Re: Zoom box
« Reply #2 on: May 23, 2007, 11:33:53 AM »
Hi Klmark
Yes i know thats how to do it but i meant if i forgot to drag and just release the mouse button then my object is gone.
Thats a big punish for such a smal mistake.
Greetings:
Willem
Offline klmark
  •  107 107
Re: Zoom box
« Reply #3 on: May 23, 2007, 01:26:48 PM »
Hi
Because it is zoom in so big you think it is but it ant Just double click the left mouse it will bring it back to orig seize
Re: Zoom box
« Reply #4 on: May 23, 2007, 01:40:08 PM »
Ah why did i not think of that.
Thanks Klmark.
Greetings:
Willem
Re: Zoom box
« Reply #5 on: May 27, 2007, 07:38:45 PM »
sounds like it is all fixed ;)
www.newfangledsolutions.com
www.machsupport.com
Re: Zoom box
« Reply #6 on: May 28, 2007, 10:44:17 AM »
Hi Brian
Yes the problem is solved but it would be nice if a minimum size of the zoombox is required to activate the action.
Greetings:
Willem
« Last Edit: May 28, 2007, 10:46:28 AM by W.Jansen »
