Hello Guest it is November 24, 2026, 01:25:52 PM
Author Topic: M99  (Read 8996 times)
M99
« on: June 11, 2016, 01:12:38 PM »
M99 (return from sub routine) does not work on my machine anymore, any ideas?
am I gonna have to do a reinstall? if so, which xml file do I save and where do I put it? !!!!
best regards,
Wayne
P.S. the version is R3.043.066 and its licenced
Neither does M1 or M30  work :-\
  •  9,378 9,378
Re: M99
« Reply #1 on: June 13, 2016, 12:42:03 AM »
Your Profile is shown bottom right of screen. Your current settings are stored in the file <your profile>.xml, which is located in the Mach3 folder.
Mach3 stores backup .xml files so, before re-installing, try using;  Operator / Restore Settings and install a previous .xml. Hopefully you have one which was made prior to you having the M99/M1/M30 issues.
