Mach Discussion => General Mach Discussion => Topic started by: crozjota on June 11, 2016, 02:12:38 PM
M99 (return from sub routine) does not work on my machine anymore, any ideas?
am I gonna have to do a reinstall? if so, which xml file do I save and where do I put it? !!!!
best regards,
Wayne
P.S. the version is R3.043.066 and its licenced
Neither does M1 or M30 work :-\
Your Profile is shown bottom right of screen. Your current settings are stored in the file <your profile>.xml, which is located in the Mach3 folder.
Mach3 stores backup .xml files so, before re-installing, try using; Operator / Restore Settings and install a previous .xml. Hopefully you have one which was made prior to you having the M99/M1/M30 issues.
