Hello Guest it is November 23, 2026, 02:05:35 AM
Author Topic: Emergency stop not working  (Read 9065 times)
« on: May 22, 2007, 12:49:33 PM »
Hi to the the forum as I am new,
been working with mack 3 for a couple of weeks and had my machine setup tht if I hit the emrgeny stop switch on screen,  the z would move to safe height. I set this in config\safe z setup. this used to work but I had a little miss hap(my fault) and when I hit stop nothing happened to the z. any help would be appreciated I am running mach version R2.00.065 hope someone can help.
Re: Emergency stop not working
« Reply #1 on: May 27, 2007, 12:33:06 PM »
This was fixed off line and  the problem was that the tool will not pickup if you hit the reset button... only the stop button.
(Wanted to have this if any other people had the same  question ;) )
www.newfangledsolutions.com
www.machsupport.com
