Hello Guest it is November 13, 2026, 09:28:48 PM
Author Topic: Pokeys 57E Soft Limits  (Read 10924 times)
« on: June 02, 2016, 06:15:01 AM »
Pokeys57E and MachMotion Apollo III (Model X15-A3-V1.0)
When I use the Jog buttons on the Pokeys57E the Soft Limits do not seem work. Is this a setup problem?
Thank you,
Jerry D
Offline NeoTO
  •  504 504
    • PoLabs
Re: Pokeys 57E Soft Limits
« Reply #1 on: June 18, 2016, 02:37:45 PM »
The soft limits in Mach3 are usually handled by the motion controller device directly. If I understand you correctly, the PoKeys57E device is used as an input device - in this case, it only forwards the information to Mach3, so either Mach3 or Apollo should take care of the soft limits.
www.poscope.com home of PoKeys USB HID, IO, USB, Ethernet controler and PoScope USB PC oscilloscope
