Third party software and hardware support forums. => PoKeys => Topic started by: thejerryguy on June 02, 2016, 07:15:01 AM
Pokeys57E and MachMotion Apollo III (Model X15-A3-V1.0)
When I use the Jog buttons on the Pokeys57E the Soft Limits do not seem work. Is this a setup problem?
Thank you,
Jerry D
The soft limits in Mach3 are usually handled by the motion controller device directly. If I understand you correctly, the PoKeys57E device is used as an input device - in this case, it only forwards the information to Mach3, so either Mach3 or Apollo should take care of the soft limits.
