Hello Guest it is October 12, 2026, 10:06:58 PM
Author Topic: Writing to machine.ini  (Read 16475 times)
« on: May 26, 2016, 10:48:00 PM »
I'm writing to the ini file for saving persistent DRO's and it works great.  I'm setting up some check boxes using toggle buttons and images and I'm trying to save the state of the button to the ini file on screen unload.  It doesn't work.  It should be saving the button state in the Preferences section, but it's not.  I inserted a message box and it is capturing the button state, just not writing it to the ini.  Code is below.  What am I doing wrong?
inst = mc.mcGetInstance()
val = scr.GetProperty('togCheck1', 'Button State')
mc.mcProfileWriteString(inst, "Preferences", "togCheck1", string.format (val))
Offline DazTheGas
  •  778 778
  • DazTheGas
Re: Writing to machine.ini
« Reply #1 on: May 27, 2016, 02:13:01 AM »
have you tried tostring(val)
Im away from a computer so cant check myself.
DazTheGas
Offline dude1
  •  1,253 1,253
« Reply #2 on: May 27, 2016, 04:05:49 AM »
4.4 in the scripting manual
« Reply #3 on: May 27, 2016, 08:19:25 AM »
I'm pretty much doing exactly what's in the scripting manual, but I changed the code to match the manual exactly and still nothing.  Is it possible that mc.mcProfileWriteString in the unload script is trying to write to the ini file while another process is writing to it?  Or will one wait fro the other to finish?
Offline DazTheGas
  •  778 778
  • DazTheGas
« Reply #4 on: May 27, 2016, 08:45:19 AM »
You are not actually writing to the file, you are writing to internal registers, the last thing mach does before closing is to write these registers to the machine.ini
DazTheGas
« Reply #5 on: May 27, 2016, 08:50:38 AM »
So what I did is I put this code in the button Down Script...
mc.mcProfileWriteString(inst, "Registers", "togCheck1", "1")
And this code in the Button Up script....
mc.mcProfileWriteString(inst, "Registers", "togCheck1", "0")
And this works.  Must some sort of conflict with doing this in the unload script.  Maybe Mach is writing the ini file before the unload script runs.
Offline DazTheGas
  •  778 778
  • DazTheGas
« Reply #6 on: May 27, 2016, 08:57:36 AM »
Beet me to it but this works too.
Code: [Select]
mc.mcProfileWriteString(inst, "Preferences", "togCheck1", tostring(val))
DazTheGas
« Reply #7 on: May 27, 2016, 09:34:23 AM »
The button has been destroyed by the time the unload script runs so it is out of scope. You can't get the state if it isn't there. That is why I populate persistants in the first run of PLC script.
« Reply #8 on: May 27, 2016, 11:42:25 AM »
So saving the state of a button can only be done in one of the buttons event scripts, correct?  There are plenty of outputs that will never be used.  I suppose I could tie the button to an output and get the state of the output on unload.  Are the outputs readable in an unload script?
Offline DazTheGas
  •  778 778
  • DazTheGas
« Reply #9 on: May 27, 2016, 12:34:15 PM »
The state of your button is getting written to the machine.ini on clicking it with the code you had earlier, thats all you need.
DazTheGas
