Hello Guest it is November 13, 2026, 09:38:01 AM
Author Topic: Mach3 won't load G-code that has previously worked - Bad character?!?  (Read 9375 times)
I'm a bit desperate since I need to be cutting things now but can't load ANY G-code into Mach3 anymore. It says bad character on line 0 but there is nothing wrong there (before a comment) and I'm also trying to load files that I've used in the past but Mach3 claims that there are some garbage characters beginning the file, when there obviously isnt'.
Any hints would be greatly appreciated.
Patrik
Resolved: Mach3 don't like to import any G-Code that contains national characters, even in comments. All imports will be "corrupt" after that.
Solved by restarting Mach3 and cleaning the new G-codes from Swedish characters...
« Last Edit: May 26, 2016, 05:09:51 AM by goswatches »
Offline rcaffin
  •  1,073 1,073
Yep, just basic single-byte ASCII characters.
Roger
