Hello Guest it is November 02, 2026, 10:09:05 PM
Author Topic: digitize light  (Read 9567 times)
Offline PCH
  •  80 80
digitize light
« on: May 11, 2016, 01:55:06 PM »
Got everything hooked for my zero tool plate correctly
went into diagnostics and the digitize light is already on and
I have not made the connection :-\  disconnected wires
from breakout board and still it is on.  Restarted Mach and light is
still on.  Light should be off normally correct? ???
Offline Davek0974
  •  2,606 2,606
Re: digitize light
« Reply #1 on: May 11, 2016, 02:14:31 PM »
Yes off normally
Is the probe input configured in ports&pins?
Offline PCH
  •  80 80
Re: digitize light
« Reply #2 on: May 11, 2016, 02:30:28 PM »
It is.  I have found that if I uncheck active low the light goes out.
The light comes on when I complete the circuit.  Now it works.  Not sure why
as the video I watched said to put the green check mark for active
low in the ports & pins for the probe.
Offline Davek0974
  •  2,606 2,606
Re: digitize light
« Reply #3 on: May 11, 2016, 02:35:06 PM »
Thats the one :)
Nice one.
Re: digitize light
« Reply #4 on: May 11, 2016, 05:40:20 PM »
 Hi PCH it depends on what the N.O. state is.
Regards
Charlie M.
