Hello Guest it is November 23, 2026, 12:35:38 AM
Author Topic: x axis moving in wrong direction and not homing  (Read 8370 times)
« on: May 11, 2016, 12:56:32 AM »
I'm using dmm servos and their break out board    z axis and y axis  home and move off the combo limit/home switches, but the x axis just hits the limit switch and trips the limit switch  not working it as a homing switch.  I tried messing about in the home/ limits setup area  and can then get the x to move the right direction  when running a wizard program  but instead of climb milling as programed its conventional milling    thanks,  Chris
Offline CES
  •  62 62
Re: x axis moving in wrong direction and not homing
« Reply #1 on: May 07, 2018, 02:58:17 PM »
Check Thank you have Ports and Pins assigned correctly. In my Mill, X is not inverted, Y is inverted and Z is not.
« Last Edit: May 07, 2018, 03:00:59 PM by CES »
