Hello Guest it is October 25, 2026, 03:42:07 AM
Author Topic: Who can help ? my X-axis only wants to move in 1 direction  (Read 10937 times)
Hi there,
I just changed from a parallel situation to USB, Parallel is just too old and not stable enough for me.
I bought an XhC Mach3 USB control card (4 axis). I wired everything, checked and double checked. Y/Z works fine. The X-axis only wants to move in 1 direction when toggled. I tried about every function n Mach3, i just cannot invert the direction, and am not able to make it goi in both directions. I checked the wire from driver to the controlcard and "beeped"it. The cable is ok. All drivers have exactly the same dipswitches activ, same drivers, same steppermotors.
The last few hair i have go grey, can some-one help me ?
Thanx in advance
Fred
Re: Who can help ? my X-axis only wants to move in 1 direction
« Reply #1 on: May 09, 2016, 04:06:44 PM »
swap motors to identify is motor and wiring ok, swap just driver to ensure driver ok, double check config.
« Reply #2 on: May 10, 2016, 03:15:21 AM »
i swapped the wiring between USB card and Driver from X axis to Z axis. Now the Z axis only moves to one side only, and X moves normal.
Does this mean the USB control card has a malfunction?
« Reply #3 on: May 14, 2016, 04:29:43 AM »
I found the error. It was the direction wire that did not make good contact.
