Hello
Guest
it is
November 22, 2026, 09:30:08 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
TOOLPATH
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: TOOLPATH (Read 9904 times)
GRAYHIL
202
TOOLPATH
on:
May 07, 2016, 04:31:04 PM »
Hi all
Version 062 on Win 7
When I load the attached program and look at the program limits on the Toolpath display it displays
x-.125 x+.5347
y-.125 y1.2104
If I then set the scale to x-1 for a mirror image and regenerate the toolpath display I get
x-.5437 y+.125
y-.125 y+1.3365
I can understand the x changing sides but why does the y change as I have not altered that y scale?
Graham
ger21
6,295
Re: TOOLPATH
Reply #1 on:
May 07, 2016, 07:19:46 PM »
It looks like the Y1.2104 is wrong.
It should be 1.3365 in both cases.
GRAYHIL
202
Re: TOOLPATH
Reply #2 on:
May 08, 2016, 04:15:13 AM »
Thank you Gerry
Is it a fault in Mach 3 version 62 then?
I will run the program and see what happens when I do the second side.
Graham
ger21
6,295
Re: TOOLPATH
Reply #3 on:
May 08, 2016, 06:49:35 AM »
I think it's just a bug in the value of the limits that's displayed. If you jog the machine so that the line on the toolpath display is aligned with the very top of the toolpath, you'll see that the part is in the same location both ways.
GRAYHIL
202
Re: TOOLPATH
Reply #4 on:
May 08, 2016, 08:03:24 AM »
Hi Gerry
I planned to do something similar but by mounting a clock gauge on the Y axis and physically running both variants without a tool to see if the clock read the same.
Graham
Print
Pages:
1
Go Up
« previous
next »
